It is currently Thu Apr 18, 2024 2:28 am
 Post subject: Main traveler direction
PostPosted: Sat Jan 19, 2013 9:52 am
I didn't note which way the traveler car faces when I removed it from the track. Is there a front and back? It doesn't look the same on both sides.
PostPosted: Sun Jan 20, 2013 11:36 am
The open side faces aft. Looks like it would work either way though.
PostPosted: Tue Jan 22, 2013 5:20 pm
I think you are right. I tried it both ways and it seems to rest against the track better when it's tipped over (when there is lots of slack on the main sheet) this way. I thought I remember seeing something a post a while back about there being a right way this should face.
PostPosted: Wed Jan 23, 2013 7:40 am
If you have an older boat with two block hangers on the boom I prefer to use the forward one. When I use the aft hanger the traveler seems to bind under wind load due to the lower angle.
