The Hobie 17 mast is very flexible, but it should be straight. If the mast has a permanent bend to it, I would suspect that is occurring in the aluminum section. It could also be an issue that the comptip has loosened up where it is installed in the aluminim mast. It would be very rare for the comptip itself to take a bend, but if it did, you could try bending it back by using weights to pull it back straight. This would take a while, but eventually the fiberglass should be able to be bent back in the opposite direction.
I think the first thing you need to do is really determine where on the mast the bend is occurring.
