It is currently Thu Mar 28, 2024 5:12 am
PostPosted: Wed Nov 15, 2017 3:02 pm
The screw that attaches the base of ARC cranks to the drums must be properly tensioned to hold the crank against the drum adjustment holes.
Tension the screws to add a moderate amount of friction to the fore and aft movement of the ARC cranks. A loose screw could allow the crank to move away from the adjustment holes and possibly strip the outer plastic away between adjustment holes.
The ARC crank drives use a 7/32” Allen Wrench.
