Riverman1 wrote:
If anybody is following this thread, you can actually use the sidekicks on Gear Trac on a Revo without an adapter plate. The key is to mount the tracks parallel with each other. In other words they do not follow the curve of the yak.
Riverman1 I understand the importance of the gear track being parallel. But I don't understand how that alleviates the need for backing plates. If you get stuck in big swells and take one sideways (or any other scenario that creates a lot of upperward force on the sidekick) without a backing plate that gear track could easily be ripped out especially if screws were used. I've seen in happen several times with rod holders being used on gear tracks. Seen it twice on a Hobie Compass with the gear tracks that on each side of the cockpit area.
