| Oasis paddle storage and cart questions http://www.hobie.com/au/en/forums/viewtopic.php?f=11&t=10259 |
| Author: | soundandfury [ Tue Aug 05, 2008 12:42 pm ] |
| Post subject: | Oasis paddle storage and cart questions |
Anyone know if it's possible to slide half a standard paddle into the Oasis hull? And, has anyone used the mini kayak cart? Are there any other cart options that will fit through an 8" hatch? ...thanks Frank |
| Author: | Roadrunner [ Wed Aug 06, 2008 10:11 pm ] |
| Post subject: | |
Hi Frank and welcome to the forum. The standard paddle will not fit through any of the three Oasis hatches, but Hobie sells a 4 piece paddle that should fit in at least 2 of the hatches. Or, you could possibly cut a paddle down if you don't like the standard paddle mounts. Check out Stringy's posts for storing the cart upside down in the nose of the front cockpit or consider a couple of padeyes and bungee it on the foredeck if you can't use the aft cargo well. If there's a will, .... |
| Author: | soundandfury [ Thu Aug 07, 2008 12:59 pm ] |
| Post subject: | |
Thanks for the paddle info, I'll get a telescoping one then. I will be storing the boat at a marina and the more I can store in the hull, the less to haul there and back, especially when I bike. |
| Author: | Thomas [ Mon Aug 25, 2008 6:05 pm ] |
| Post subject: | |
I have the older plugin cart and usually just store it in the back of my Outback using the standared bungy "net". But as I looked at it one day I relized that the golf cart wheels have a simple set screw arangement where one simply unscrews and removes the wheels. I also found that with the wheels removed, I can just barely fit the metal frame into the front hatch and dump the wheels in as well. But since I don't use the rear area much, I just store it there most times. thomas |
| Author: | soundandfury [ Wed Aug 27, 2008 2:51 pm ] |
| Post subject: | |
That's good to know. I'll check out the newer cart next time I'm at a dealer. |
