| Plastic adheseive http://www.hobie.com/au/en/forums/viewtopic.php?f=11&t=23084 |
| Author: | NJ Phil [ Thu Apr 08, 2010 3:57 am ] |
| Post subject: | Plastic adheseive |
What type of plastic is the Revolution made of? Will Polyurethane construction adhesive hold on it? In order to eliminate "skeg rash" I made a stainless steel cover for the skeg. I could attach it with bolts but I'd rather not drill in the bottom below the waterline, if I don't have to. |
| Author: | mmiller [ Thu Apr 08, 2010 9:17 am ] |
| Post subject: | Re: Plastic adheseive |
The kayaks are molded from Polyethylene. There has been discussion in these forums about adhesives. I believe roadrunner discovered that a 3M Scotch Weld DP 8010 was quite good. |
| Author: | NJ Phil [ Thu Apr 08, 2010 9:44 am ] |
mmiller wrote: The kayaks are molded from Polyethylene. There has been discussion in these forums about adhesives. I believe roadrunner discovered that a 3M Scotch Weld DP 8010 was quite good. If I used bolts, would it void the warranty? |
| Author: | mmiller [ Thu Apr 08, 2010 9:54 am ] |
If the boat were to crack due to drilling and using bolts? That would not be covered by warranty. Would not effect any other issue that might come up. |
