| Leak at front handle - Odyssey http://www.hobie.com/au/en/forums/viewtopic.php?f=11&t=25115 |
| Author: | yansheng_wei [ Mon May 24, 2010 7:50 am ] |
| Post subject: | Leak at front handle - Odyssey |
I got an Odyssey about 8 years old several weeks ago. The first time we went on the lake, I found a leak at the front. After some investigation, I found out the leak is from the hole where the front rope handle goes. I took out the handle, and I can see there is a hole there (hole in hole). I also found that the hole is filled with some kind of glue, not the hull material (HDPE). I can see there is a patch of glue from the inside (it would show at the nose tip, and It thought it was mud earlier). I am also of the belief that the glue was not a fix, but rather part of the original design/build. I used the 3M DP-8010 to fix a crach at the foot well, but not sure how to fix a hole in a glue.
- Yansheng |
| Author: | mmiller [ Tue May 25, 2010 9:56 am ] |
| Post subject: | Re: Leak at front handle - Odyssey |
Can't imagine a handle being much of a leak area, but simple adhesive sealant should fix something like that. How about a photo of the area? I can't recall the setup from 8 years ago at the moment. |
