| Drum lubrication on Twist-n-Stow Rudder http://www.hobie.com/au/en/forums/viewtopic.php?f=11&t=28162 |
| Author: | Titan4 [ Tue Jul 20, 2010 5:57 pm ] |
| Post subject: | Drum lubrication on Twist-n-Stow Rudder |
I am getting ready to put a new tube and line kit (80020001) in my Outback Twist-n-Stow Rudder (Up/Down control) and have been reviewing the Hobie docs. I may be overlooking it, but is there any recommended lubricant when reassembling the drum housing on the rudder? Will a shot of V & S 781 Dry Silicone do the trick or is anything necessary? Apologies if this has been covered in numerous posts already. I did a quick search, but did not find it. |
| Author: | Roadrunner [ Tue Jul 20, 2010 8:55 pm ] |
| Post subject: | Re: Drum lubrication on Twist-n-Stow Rudder |
Personally, I would omit any lube on the hollow bolt threads, as you want it to hold its adjusted position. I like dry silicon for any other moving parts though (lines, washer and rotating rudder mount at bolt head). |
