| Hobie Pursuit question http://www.hobie.com/au/en/forums/viewtopic.php?f=11&t=41820 |
| Author: | guyrichter [ Tue Mar 27, 2012 6:37 am ] |
| Post subject: | Hobie Pursuit question |
We bought 2 older Hobie Pursuit kayaks 12'. They have an oblong hole in the hull up between your legs. Therefore, water inside the kayak seeks the same level of the surrounding lake water. That means your heels (at least) get wet. Sometimes it gets deeper in the boat and sloshes up to the seat. I assume this "hole" in the hull is designed to let water back out if the boat takes on a big wave? Is there a scupper plug that would fill this hole? Could I seal it permanently? Thanks for any help! |
| Author: | Jbernier [ Tue Mar 27, 2012 8:34 am ] |
| Post subject: | Re: Hobie Pursuit question |
There is a scupper plug that you can insert - just order from any dealer (part # 72009001) |
| Author: | guyrichter [ Tue Mar 27, 2012 8:45 am ] |
Thanks for the tip! I'll order a couple. I was on Hobie website but couldn't find a plug. |
| Author: | carrie2275 [ Wed Aug 23, 2017 1:05 pm ] |
Hello I just got a Pursuit, used around 2009-2010 (owner wasn't sure) and I found water has come into the inside of the boat. I drained it using the plug but am concerned about it filling as I ride. Haven't tested it out too much. I saw your posts about the plugs - did you find a plug? Did you find it helped? Any advice on that? I love the bought and want to be able to use it without worrying about filling with water too much. Thanks! -Carrie |
