| Hobie speedometer as a training aid http://www.hobie.com/au/en/forums/viewtopic.php?f=11&t=4288 |
| Author: | Havoc [ Sat Oct 14, 2006 9:57 pm ] |
| Post subject: | Pitot Tube Maesurment Units |
Does the Pitot Tube measure in MPH or Knots? |
| Author: | Roadrunner [ Mon Oct 16, 2006 11:13 pm ] |
| Post subject: | |
Pretty sure it's MPH, but it's best to think of the marks as reference units, until you "calibrate" the scale with a GPS. It depends on how far it sits in the water to begin with -- different with the Adventure than the Tandem, for example; body weight, placement of gear, etc. all have an effect. Once calibrated for you and your boat, you can figure the correction. For example, at 180 #, with the Adventure, I add 1 mph up to "4", and 1.3 above 4MPH to approximate GPS speed (maybe the bow rises a bit)? |
| Author: | Roadrunner [ Wed Nov 15, 2006 9:57 pm ] |
| Post subject: | |
With the local lake closed for the winter, I've been spending more time in the local harbors/bays. Lately there has been a lot of seaweed grass fouling the fins and rudder. The speedometer picks up on the drop in speed immediately before it would otherwise be noticeable. It's surprising how little debris it takes to slow the boat down by 1 to 1.5 MPH! |
| Author: | Roadrunner [ Wed Jun 27, 2007 11:29 pm ] |
| Post subject: | |
Not to bring up an old topic again BUT, I've recently discovered a new use for the Hobie speedometer. If you already have it calibrated, you can use it in conjunction with a GPS to detect currents and tides. For instance, If you already know your actual speed is .5 MPH faster than your speedo but today it is reading only a .3 difference, you are probably going against a small local current. You may be able to move to one side or the other and improve your headway. Even in the lake I started noticing subtle currents that are not otherwise visible. It's a great instrument -- I use it almost constantly. |
| Author: | Apalach [ Thu Jun 28, 2007 6:35 am ] |
| Post subject: | |
Hey RR, Good information--thanks. However, I had heard Hobie was no longer providing those with the Mirage Drive, or was planning on discontinuing them. Anyone know?? |
