| Drive mast stuck in sprocket http://www.hobie.com/au/en/forums/viewtopic.php?f=11&t=46366 |
| Author: | jpeight [ Sun Jan 27, 2013 2:52 pm ] |
| Post subject: | Drive mast stuck in sprocket |
Hi - Quick question on the V2 sprocket. I have a bent mast stuck in the sprocket hole. In trying to loosen it, I managed to loosen the brass insert in the sprocket itself - now the whole assembly (mast and insert) spins inside the sprocket. I can replace the sprocket, but thought I'd see if there are any ways to salvage this. Next time I'll try a little heat before I turn the wrench... |
| Author: | KayakingBob [ Sun Jan 27, 2013 3:33 pm ] |
| Post subject: | Re: Drive mast stuck in sprocket |
Time for a new sprocket! Sometimes they use a bit too much Loctite on them at the factory |
