| Serial numbers? http://www.hobie.com/au/en/forums/viewtopic.php?f=11&t=47553 |
| Author: | joco [ Sun May 12, 2013 6:10 am ] |
| Post subject: | Serial numbers? |
Just baught and old style hobie outback and want to no info about it. Where is the serial number on those? The seat is done Have to change all bungee cord Tune up on the mirage drive Change the cord to the back rudder both side Seem to be some kind off something under the masss hole under the hull....mmmm will have to look at this. The mirage drive hole seems to be low in the hull,,,,look like below water line,,,is there water that will acumulate there? Thanks Joco |
| Author: | islandspeed2001 [ Sun May 12, 2013 5:35 pm ] |
| Post subject: | Re: Serial numbers? |
Right rear should have the serial numbers. |
| Author: | Flyfsh [ Tue May 14, 2013 6:33 am ] |
When I use the outback I put my cooler with drinks in the front. I weigh 200lb and the water just barely comes into the yak. Just my heels get wet. Jim |
