| Cabling required for Evolve V1 motor on 2nd hull http://www.hobie.com/au/en/forums/viewtopic.php?f=11&t=47732 |
| Author: | Yakaholic [ Fri May 24, 2013 10:23 am ] |
| Post subject: | Cabling required for Evolve V1 motor on 2nd hull |
First off I am very pleased with the performance and versatility of the Toqueedo kit I got many years ago. I have the original Evolve motor (V1) mounted to fit in mirage drive well. I have the V2 battery upgrade from a recall - it came with a new charger and an adapter to fit the V1 (original) cable. Works great! I would now like to installs this setup on a 2nd kayak (a tandem oasis) and want to be sure what I get will work correctly. I see there is a #72022031 - EVOLVE v2 CABLE KIT (2ND HULL) listed for $175 Am am I correct in assuming this is all I need? That I would remove the battery adapter pigtail and that this cable would buckle up the the motor no problems? I further assume that the original controller would work and that I would also get a set of "through the hull" fittings? Thanks Hopefully Matt or some Hobie tech will clarify Yakaholic |
| Author: | Jbernier [ Fri May 24, 2013 10:42 am ] |
| Post subject: | Re: Cabling required for Evolve V1 motor on 2nd hull |
Yes - that is correct. The cable kit will let you use your eVolve on a 2nd hull easily. |
