| Bent Mast Rod http://www.hobie.com/au/en/forums/viewtopic.php?f=11&t=5063 |
| Author: | ganiom [ Mon Oct 02, 2006 1:16 pm ] |
| Post subject: | Bent Mast Rod |
Any suggestions on the best way to straighten a bent mast rod? I believe I struck a submerged Trident submarine...it took quite a shot. The mast appears to have pulled away at the top. Thanks for any help ! Mike |
| Author: | mmiller [ Mon Oct 02, 2006 2:08 pm ] |
| Post subject: | Bent |
Take it to a vise and tap straight with a mallet. If you have to, with the drive mounted you can roll the boat on its side and pull on the mast to bend forward. |
| Author: | ganiom [ Sat Oct 07, 2006 9:29 am ] |
| Post subject: | |
Thanks Matt Should I remove the mast first? Mike |
| Author: | mmiller [ Sun Oct 08, 2006 9:32 am ] |
| Post subject: | Mast |
If you want to do it in a vise...yes, remove the mast from the drive. |
