| OLD style Rudder install HELP !!! http://www.hobie.com/au/en/forums/viewtopic.php?f=11&t=53036 |
| Author: | wally3128 [ Thu Oct 02, 2014 3:26 pm ] |
| Post subject: | OLD style Rudder install HELP !!! |
Greetings, Sonny Boy bought an older Hobie Marage Kayak. Rudder was removed for who know's why. New "OLDER" ( NOT Twist and tilt ) rudder is inhand and bolted to the Kayak. Left and right cables connected and work fine. HOW !!!! does old Dad connect the up and down controls ???? Single handle up and down. After 5 hours...I am just about to give up!!! Thank you in Advance... Wally |
| Author: | stringy [ Thu Oct 02, 2014 6:00 pm ] |
| Post subject: | Re: OLD style Rudder install HELP !!! |
There was a video but it doesn't seem to working viewtopic.php?f=21&t=12565 Hobie??? Looks like the PDF's here are all to do with the twist-n-stow? http://www.hobiecat.com/support/ viewforum.php?f=21 You might have to contact Hobie directly. |
| Author: | wally3128 [ Thu Oct 02, 2014 6:44 pm ] |
Thank you, message in to HOBIE!! |
| Author: | wannabefishin [ Fri Oct 03, 2014 8:06 am ] |
Wally, I won't be back at the house until Tuesday. I can take pics of my older Mirage rudder and the up and down line connection if that would help. Sent from my iPad using Tapatalk |
| Author: | wally3128 [ Fri Oct 03, 2014 8:45 am ] |
Thank you Sir!!! My back went out so I won't be able to get to it till next week !!! |
| Author: | wannabefishin [ Tue Oct 07, 2014 11:56 am ] |
Wally, here are a couple of photos of my old style rudder and the line attachments. When the handle is pointing aft, the rudder is down. ![]() ![]() ![]() ![]() ![]() Sent from my iPad using Tapatalk |
| Author: | wally3128 [ Tue Oct 07, 2014 3:24 pm ] |
Thank you SOOOO much !!! That is exactly what I was looking for !!! Wally |
| Author: | malte [ Tue Dec 15, 2020 11:09 pm ] |
Hi, I just picked up an old Mirage tandem with the old style rudder and am looking for some help! I bought a new rudder as the old one was broken and am trying to figure out how the rudder up/down system works. Looks like all these previous posts are so old that the pics and videos are gone... The Rudder Stainless Steel Mount bar is bent to the side and I am not sure if that is because it was abused and hence the broken rudder or whether it is intended to be that way (like the newer ones)? Any help is welcome thanks Malte |
| Author: | Jbernier [ Wed Dec 16, 2020 1:05 pm ] |
The new style rudder can't be fitted to an old style hull - no.... You can usually bend the mounts back straight - if not, it's still a part you can order from a dealer here's the part: 81350001 RUDDER MOUNT-MIR $59.99 to find a dealer click here: https://www.hobie.com/dealers/ |
| Author: | malte [ Fri Dec 18, 2020 10:53 am ] |
thanks so much, I was able to bend it back straight and after adjusting the strings I can lock it into the rudder down position with the lever but the up position of the lever only releases the downward tension but doesn't lift it up. What am I missing? If I tension the upward string more it keeps it from going all the way down? |
