| Looking for Part Number for Hobie PA 14 http://www.hobie.com/au/en/forums/viewtopic.php?f=11&t=54062 |
| Author: | kinghong1970 [ Tue Mar 03, 2015 4:08 pm ] |
| Post subject: | Looking for Part Number for Hobie PA 14 |
Hello folks, trying to find out a part number for a Pro Angler... ![]() i am looking for the part number for the 2015 pro angler 14 side handle bar (the metal tube in between the plastic end molds) the older PA have a round tube, whereas the new one has flat surfaces as so the attachments don't slip.,.. thanks in advance, Al |
| Author: | mmiller [ Tue Mar 03, 2015 5:48 pm ] |
| Post subject: | Re: Looking for Part Number for Hobie PA 14 |
Not yet available as an accessory purchase. We have a kit in process, but will not be available until later this spring. |
| Author: | kinghong1970 [ Tue Mar 03, 2015 7:09 pm ] |
tyvm! |
| Author: | kinghong1970 [ Wed Mar 04, 2015 9:27 am ] |
mmiller wrote: Not yet available as an accessory purchase. We have a kit in process, but will not be available until later this spring. Matt, do you, by chance, have a part number for a 2015 Pro-Angler rear bar replacement? the Decagon (?) shaped bar? i saw the new PA's are shipped with the flat edged bar... is this the round version or the Decagon version? 84504201 TUBE, STERN HANDLE thanks! |
| Author: | mmiller [ Wed Mar 04, 2015 12:45 pm ] |
We don't have any of the 2015 parts available to sell unless as a replacement for a damaged 2015 version. Once the factory is comfortable with production stock... we will be able to sell. |
| Author: | kinghong1970 [ Wed Mar 04, 2015 3:38 pm ] |
mmiller wrote: We don't have any of the 2015 parts available to sell unless as a replacement for a damaged 2015 version. Once the factory is comfortable with production stock... we will be able to sell. thanks again Matt... time to ramp up some productions!!! hahaha i guess the new release of the H-crate also delays the availability of the parts too, eh? |
| Author: | kinghong1970 [ Thu Mar 05, 2015 7:21 am ] |
Ok, one more question... Hobie Sidekick Mount Bracket Assembly, 72062021(top) & 72062011(bottom), when assembled, what is the Diameter of the hole? or rather, what size tubing does hobie use for their AMA? |
| Author: | mmiller [ Thu Mar 05, 2015 9:04 am ] |
kinghong1970 wrote: i guess the new release of the H-crate also delays the availability of the parts too, eh? Just a LOT of new stuff this year. |
| Author: | mmiller [ Thu Mar 05, 2015 9:05 am ] |
kinghong1970 wrote: Ok, one more question... Hobie Sidekick Mount Bracket Assembly, 72062021(top) & 72062011(bottom), when assembled, what is the Diameter of the hole? or rather, what size tubing does hobie use for their AMA? It was originally our paddle shaft when aluminum. Looks to be 1 1/8". |
