| Hobie H-Rail Bolt On Kit 9" Install http://www.hobie.com/au/en/forums/viewtopic.php?f=11&t=56820 |
| Author: | CastAway4 [ Mon Feb 01, 2016 8:38 pm ] |
| Post subject: | Hobie H-Rail Bolt On Kit 9" Install |
Hi Guys, I just purchased the Hobie H-Rail Bolt On Kit 9" for my Outback. What size drill bit should be used to install this? I was looking for a youtube Video or some PDf instructions from Hobie. Hobie is good for posting things like this but I didnt find anything. Thanks! |
| Author: | mmiller [ Tue Feb 02, 2016 9:55 am ] |
| Post subject: | Re: Hobie H-Rail Bolt On Kit 9" Install |
The provided screws are 1/4-20, so a 1/4 inch bit should do it. |
| Author: | CastAway4 [ Tue Feb 02, 2016 7:18 pm ] |
Thanks mmiller for the quick reply. I wanted to be sure before I put holes in my new outback LE. Can't wait to install. |
| Author: | crazyexplorer [ Wed Feb 03, 2016 12:19 pm ] |
can you post picture after you install it. Would like to see how it is since I'm looking at this. Thanks. |
| Author: | stringy [ Wed Feb 03, 2016 2:42 pm ] |
To prevent leaks I use a drill two sizes smaller than the screw. The screw then becomes a 'tap' which cuts it's own threads into the plastic, making for a water tight seal. |
| Author: | Thinwater skinner [ Thu Feb 04, 2016 7:20 am ] |
stringy wrote: To prevent leaks I use a drill two sizes smaller than the screw. The screw then becomes a 'tap' which cuts it's own threads into the plastic, making for a water tight seal. 2X on this!!! Works very well. |
| Author: | CastAway4 [ Thu Feb 04, 2016 6:50 pm ] |
crazyexplorer wrote: can you post picture after you install it. Would like to see how it is since I'm looking at this. Thanks. Sure! I will post some pictures after its installed. |
| Author: | CastAway4 [ Thu Feb 04, 2016 6:51 pm ] |
stringy wrote: To prevent leaks I use a drill two sizes smaller than the screw. The screw then becomes a 'tap' which cuts it's own threads into the plastic, making for a water tight seal. Good advice. I will definitely look at this as an option when installing. |
