| Solo losing outback on GMC Yukon http://www.hobie.com/au/en/forums/viewtopic.php?f=11&t=59248 |
| Author: | CBG45 [ Mon Oct 03, 2016 10:11 pm ] |
| Post subject: | Solo losing outback on GMC Yukon |
Any advice for loading a outback on a Yukon ? I'm between the Malone k-rack and possibly a T-bar that swings. Anyone with personal experience on a suv that height ? |
| Author: | HStrech [ Tue Oct 04, 2016 10:11 am ] |
| Post subject: | Re: Solo losing outback on GMC Yukon |
I'd suggest the T-Load Hitch Mount by Rhino Rack:
Rhino 2" Ball T-Loader - part no. 72040014 YouTube link to a product overview on the T-Loader: https://www.youtube.com/watch?v=XPc7_spouC8 ![]()
| Author: | pmmpete [ Wed Oct 05, 2016 8:10 am ] |
Lay a towel over the back end of the Yukon's roof. Position your Outback with its bow next to one of the rear tires and its stern on the centerline of the Yukon. Lift the nose onto the towel. Go to the stern, lift it, and slide the kayak forward onto your roof rack. Stand on the threshold of one of the passenger doors and flip the Outback over onto its gunwales. Strap it down, and tie a rope between the bow and the passenger side towing loop under the front of the Yukon. If the rudder mechanism hits the ground when you lift the bow onto the towel, position the kayak with its stern next to a rear tire and its bow on the centerline of the Yukon. Cost of towel - under $5.00 at a discount store. Effort required - very little. |
| Author: | fusioneng [ Wed Oct 05, 2016 3:23 pm ] |
We have had 3 yukons and car top many different Hobie models. I don't recommend the towel idea, on all our yukons that rear area is all plastic. I also don't recommend just putting a towel over the rear door (we caved in one of our doors on the top lip). The best setup we found is the T-bar reciever hitch. The ones that tilt down are even better. If you have the factory roof rack that's all you need. What we do is just slip some pvc tubing under the boat on the 11 inch grooves that run the length of the boat, then tie the whole works down. The T bar supports the majority of the weight. Definately use ratchet straps, I always secure the bow with V ropes (not 1" straps (they flutter in the wind)). The nice thing about the pvc pipes and the t-bar is nothing is left on the roof or the car when not kayaking. We just throw the loose pvc pipe in the garage when not using them, Your only taking about ten bucks worth of pvc, you can also store your boat on the ground in your garage on the same pvc tubes. We just slide our kayaks around in the garage on the pvc, who cares if the pvc gets scratched on the floor. Hope this helps |
| Author: | pmmpete [ Wed Oct 05, 2016 6:47 pm ] |
fusioneng wrote: We have had 3 yukons and car top many different Hobie models. I don't recommend the towel idea, on all our yukons that rear area is all plastic. The rear wind deflector on my 4-Runner is also plastic, but it handles the weight of kayaks fine. The towel prevents my kayak, and the sand and whatnot on its bottom, from scratching up the plastic. |
| Author: | CBG45 [ Thu Oct 06, 2016 4:51 pm ] |
fusioneng wrote: We have had 3 yukons and car top many different Hobie models. I don't recommend the towel idea, on all our yukons that rear area is all plastic. I also don't recommend just putting a towel over the rear door (we caved in one of our doors on the top lip). The best setup we found is the T-bar reciever hitch. The ones that tilt down are even better. If you have the factory roof rack that's all you need. What we do is just slip some pvc tubing under the boat on the 11 inch grooves that run the length of the boat, then tie the whole works down. The T bar supports the majority of the weight. Definately use ratchet straps, I always secure the bow with V ropes (not 1" straps (they flutter in the wind)). The nice thing about the pvc pipes and the t-bar is nothing is left on the roof or the car when not kayaking. We just throw the loose pvc pipe in the garage when not using them, Your only taking about ten bucks worth of pvc, you can also store your boat on the ground in your garage on the same pvc tubes. We just slide our kayaks around in the garage on the pvc, who cares if the pvc gets scratched on the floor. Hope this helps Thanks for the advice, I appreciate all the input. I'm not sure what you mean by "11 inch grooves " any possibility of a photo? I'm l leaning towards the t bar in the above photo. The movement would be helpful, I'll hopefully be using it once a week or so. |
