| Which newer version pedal drives fit older Outback hull? http://www.hobie.com/au/en/forums/viewtopic.php?f=11&t=59526 |
| Author: | nolabayou [ Fri Nov 18, 2016 8:32 am ] |
| Post subject: | Which newer version pedal drives fit older Outback hull? |
I have a 2002 Outback with a broken chain cable on the drive. I'm debating whether to re-build or spend a little more and search for a used newer version drive. Which versions/years of the pedal drives will fit this hull? Not sure if the drive well/drive designs are universal and compatible into newer model years. Thanks. |
| Author: | mmiller [ Fri Nov 18, 2016 9:16 am ] |
| Post subject: | Re: Which newer version pedal drives fit older Outback hull? |
Any drive will work. Newer versions have alignment pins that can be cut off. |
| Author: | nolabayou [ Fri Nov 18, 2016 9:35 am ] |
Great - thanks. |
