| First post and Hobie newbie http://www.hobie.com/au/en/forums/viewtopic.php?f=11&t=61777 |
| Author: | HStrech [ Thu Nov 09, 2017 9:28 am ] |
| Post subject: | Re: First post and Hobie newbie |
Congrats on your first Hobie, and welcome to the forums! There's a wealth of information on here, and you'll find this community to be very helpful. Which specific cart do you have? There should be enough clearance for the tires to clear the bottom of your PA with our Trax, Trax 2-30 or HD Plug-In cart, as long as the post collar clamps are installed properly. A photo might be helpful. |
| Author: | Jeff Feben [ Sun Dec 17, 2017 10:33 pm ] |
Hi I cant see you first post but presume you have issues with a cart and the tyres rubbing on the Hull of a PA I use a "Sea to Summit" Cart and had the same problem My fix was to buy a "pool noodle" (AUD3) with a hole running threw it's centre , then cut the noodle to a length that allowed for it and the rubber collar , You take the collar off , put the cut down noodle piece onto the scupper shafts of the cart , then put the collar back on , this raises the collar to a height that keeps clearance between the tyres and hull , works a treat . |
