| Dent in new passport 12 hull http://www.hobie.com/au/en/forums/viewtopic.php?f=11&t=66572 |
| Author: | flyrcairplanes [ Fri May 22, 2020 6:48 pm ] |
| Post subject: | Dent in new passport 12 hull |
Just bought a new Passport 12 and my wife noted a dent in the forward hull. I have seen the video using hot water and air pressure but did not know if that would work at this location and with a thermoform hull. Any thoughts? Thanks
| Author: | mmiller [ Sat May 23, 2020 10:56 am ] |
| Post subject: | Re: Dent in new passport 12 hull |
Bummer! At least it is on the bottom and would have to effect on performance. Hot water should work. These are polyethylene, so very similar to the roto-molded versions. mmiller wrote: Easy Dent Removal
Kayaks can be dented by various means, no need to worry, they are simple to remove. Improper storage, cart use, freight/transport, too much pressure on tie-down straps all can cause a dent in a kayak. We have the solution. Watch Jacques Bernier in the video linked below. Jacques explains the simple procedure that, as you will see, can remove even a nasty dent in the side rail of a kayak. Dent Removal Video: http://www.youtube.com/watch?v=OpuIJzMotDg Success Story: ![]() ![]() ![]() ![]() |
