| retro kit http://www.hobie.com/au/en/forums/viewtopic.php?f=11&t=6678 |
| Author: | duke [ Mon May 07, 2007 2:25 pm ] |
| Post subject: | retro kit |
Can anyone tell me if Outback sn #CCMA5685404 (hard to read for sure)needs the drive well upgrade kit? If it does how do I get it? Thanks |
| Author: | valfitzandrew [ Tue May 08, 2007 10:15 am ] |
| Post subject: | |
If you have registered the hull with Hobie and it falls within the range needing the reinforcement, Hobie should have already sent the kit to you. PM Matt and ask. |
| Author: | mmiller [ Tue May 08, 2007 11:08 am ] |
| Post subject: | Retrofit? |
As per the FAQ on the kit: http://www.hobiecat.com/community/viewtopic.php?t=5469 <<Outbacks with serial numbers A3753 through F2853>> Your serial number CCMA5685404 "A5685" is within the range. Contact your dealer for the kit. |
| Author: | duke [ Wed May 09, 2007 6:27 pm ] |
| Post subject: | |
Matt I contacted my dealer here in Minnesota and they told me 2004 didn't need it. Now what. |
| Author: | mmiller [ Thu May 10, 2007 9:52 am ] |
| Post subject: | They are wrong. |
They are wrong. You can ask them to read the information again... or contact us for the correct information. Your serial number is within the range, simple as that. Which dealer? So, we can contact them. |
| Author: | duke [ Thu May 10, 2007 12:00 pm ] |
| Post subject: | |
HI Tempo |
| Author: | duke [ Wed May 16, 2007 1:44 pm ] |
| Post subject: | |
Matt I received the kit today. Thank you for the prompt response. In placing the fiberglass reinforcement it fits when pushed on, but springs back about 1/8-1/4" when released. Should I rig a brace to hold it up tight while it hardens or is it expected to have that gap? Thanks |
| Author: | ganiom [ Thu May 17, 2007 7:30 am ] |
| Post subject: | |
Use lots of the goop! With the Hobie supplied fiberglass piece at the bottom, I reinforced the entire column using about a 5-inch length of thin-wall 1-1/4 PVC. I cut out about a half-inch section, making a slot cut out from top to bottom. The thin-wall flexes and the slot snaps right around the column. Probably overkill...but there was a much more "solid" feel after the reinforcement. Good luck! |
