| Older Outback Drive Well Repair Option http://www.hobie.com/au/en/forums/viewtopic.php?f=11&t=68691 |
| Author: | beemer [ Tue Jul 13, 2021 6:28 am ] |
| Post subject: | Older Outback Drive Well Repair Option |
Have a 2010 Outback Tandem and had two drive support columns that were leaking. Thanks to Roadrunners post and others for sharing their pics and experiences as I was able to successfully repair the leaks and also applying the pvc sleeves to the other two posts that werent leaking, as a preventative measure. However, the rear set right side drive support still doesnt hold the pedals upright and wobbles while pedaling. I did the recommended 3M down the hole and reinstalled the bolt, but to no avail. I saw on YouTube that there is a replacement set for our old screw downs. Cant find info on that part anywhere??? Can anyone help me locate it? It allows you to remove the old screw drive mounts and replace with the newer. Appreciate any help with sources and also with any tips from those whove done this mod. Fellow on YouTube doesnt provide any detailed instructions or photos on the technique. THanks, and, PS I just purchased a new-to-me 2018 Compass which Im modding out and also did the Watersnake Trollling Motor mod with my Compass plug. Have yet to water test as I now have to have the yak registered here in E Tenn. |
| Author: | mmiller [ Tue Jul 13, 2021 10:13 am ] |
| Post subject: | Re: Older Outback Drive Well Repair Option |
There is no kit for that. What you saw was a 100% DIY project. |
