| Converting older pull-up rudder to twist-n-stow http://www.hobie.com/au/en/forums/viewtopic.php?f=11&t=8125 |
| Author: | stringy [ Tue Oct 16, 2007 3:48 am ] |
| Post subject: | Converting older pull-up rudder to twist-n-stow |
I have the older pull-up only rudder on my Tandem and wanted to upgrade to the larger sailing rudder to stop the weather helm I was experiencing in stronger winds. I also wanted the advantage of the twist-n-stow (t&s) which tucks the rudder up and in and out of the way. To fit the t&s Hobie have changed the kayak design and added about 50mm/2" of plastic to the stern, getting rid of the stainless pull up mechanism. They have also changed the up/down handle-making it stronger by through-bolting and the control arm up/down (not sure how but it is a different part no.) I gained the benefits of t&s by doing the following: (note -there are two parts to this “how to†|
| Author: | stringy [ Wed Oct 17, 2007 3:41 am ] |
| Post subject: | |
Thanks Roadrunner for the positive comments. Yes- you are right about the angled spacer -very observant!. I did originally think I could use a straight spacer but the rudder did hit the stern -unless I mounted it a long way back. I was reluctant to notch a brand new rudder -hence the angle. If I was doing it all over again I wouldn't cut the original mount. It would be better to notch the rudder as you said. You are also correct regarding the dual kick up methods. I have found that the original system is easier to use when on the water and the t&s is better for transport. I am working out a way to fit the extension without welding so that it would be easy to fit using standard tools. Will post when I have finished it. |
| Author: | kepnutz [ Wed Oct 17, 2007 7:34 pm ] |
| Post subject: | |
Hey Ya'll Effing brilliant mod you did there Stringy..simply top shelf RoadRunner..how bout taking those road bike's down off the wall that I see in the background of your picture of the rudder and showing them some love too.. Kepnutz |
| Author: | Flipper [ Thu Nov 19, 2009 6:23 pm ] |
| Post subject: | Re: Converting older pull-up rudder to twist-n-stow |
Stringy, I just bought what I thought was a 2009 Hobie Oasis, but it turned out to be a new 2007 model, which has the older Mirage drives and rudder. I bought a sail and want to sail the kayak in the ocean. It appears that someone modified your post how to convert the older flip-up rudder to the new twist-n-stow and removed your 2-part conversion process. Please re-post a link to the process. thanks! |
