| Hobie trax cart modification http://www.hobie.com/au/en/forums/viewtopic.php?f=11&t=9152 |
| Author: | DaveLL [ Fri Apr 18, 2008 8:50 am ] |
| Post subject: | Love it! |
What a great idea Dan! I'll be looking for the foam you mention to do this myself. If you're located in MA I bet we know each other. |
| Author: | Apalach [ Sat Apr 19, 2008 10:19 am ] |
| Post subject: | |
Hey Dan, A hearty welcome to the Hobie site. Very nice mods that should do the job as intended--congrats! Also thanks for the excellent pics. Best, Dick |
| Author: | stringy [ Sun Apr 20, 2008 2:35 am ] |
| Post subject: | |
G'Day Dan, Enjoyed your mod -great post with clear pics. The tennis balls though are the best solution I've seen for the Adventure and the other flattened hull models that deform easily. They transfer the hull weight to the scupper tubes which are much stronger. I've seen hulls at the dealers which are supported on straps in Hobie cradles deform. With my AI and Tandem I have found it best to not let the unsupported hull touch the cart at all and the use of the balls achieves this. Another plus is that they add a suspension effect and absorb bumps. |
| Author: | Roadrunner [ Sun Apr 20, 2008 10:07 pm ] |
| Post subject: | |
Dan, very nice project and an excellent improvement over the original cart. We use the same cart to carry a couple of different models, so the tennis balls seem to work ok for both of them without any changes. Either way, I think is's better for the hull to get proper support from the cart. Great job! |
| Author: | DanStratton [ Tue Apr 22, 2008 1:01 am ] |
| Post subject: | |
Thanks for the kind welcome and words of encouragement, everyone! Stringy, you've hit on the real reason I created this mod (Beyond the fun of working on it, of course). On the flatter hulled boats the tennis ball looks like an ideal solution to me. It places the weight on the scupper, a known point of strength. Given the close placement of the scuppers to the keel of the newer outback hull, I thought tennis balls would actually create more direct pressure on the sides of the keel than it alleviated on the bottom. Hence my solution.
I like to think my solution is better for the outback, but I'm not sure, not having used the tennis balls. I'm still curious though. Roadrunner, have you been running newer outback hulls on tennis balls? Any further thoughts? --Daniel BTW- DaveLL, I think the foam can be found at many kayak supply stores. Also, I'm in MT not MA, sorry. Do you know a Daniel Stratton out in Massachusetts? |
