| Hull Covers http://www.hobie.com/au/en/forums/viewtopic.php?f=123&t=63985 |
| Author: | JazonUnderwater [ Sun Sep 24, 2023 12:09 pm ] |
| Post subject: | Re: Hull Covers |
Did you happen to make plans for your 16. Id love to try this for mine. |
| Author: | ChuckC [ Wed Sep 27, 2023 10:02 am ] |
Very nice - good work. I was wondering what approach to take on my own boat and will follow this one. Thanks for sharing! |
| Author: | Jez [ Thu Sep 28, 2023 12:52 pm ] |
I don't worry about protecting the fibreglass hulls at all. I do keep the tramp wrapped under a tarp as I know the UV will damage it. |
| Author: | Josefk [ Fri Oct 06, 2023 5:36 pm ] |
JazonUnderwater wrote: Did you happen to make plans for your 16. Id love to try this for mine. I didn't make any plan for the 16. I tried a different approach with them by also adding a tramp cover in the design. It ended up being more trouble to use than separate covers and a tarp to cover the tramp so I reworked it. That said I am working on new covers for my new to me 16 at the moment. I just used the old 16 covers as a template but will try and measure and edit the 14 cover design above for you. One obvious difference is you need an opening for the shroud connections to the hulls. I used a different fabric this time as sunbrella has gone up on price at Sailrite where I bought it from. I'm in Japan and the yen has really dropped in value too which made it a bit more expensive than previously. I used a fabric called Top Gun or Top Notch, will have to check but cheaper than the sunbrella. Definitely worth the investment for me in time and money spent. The sun here can be fierce and I had really bad delam in my first 14 which had sat out uncovered for years before I got it. |
| Author: | Josefk [ Sat Oct 07, 2023 4:06 am ] |
16 hull cover dimensions. I used a material called "Top Notch" from Sailrite and you'll need to order the 60" width to allow for the widest part of the hull. I have 5 cam buckles on each cover running from the bow down the hull length, one of which is used to close the flap that I made so the covers can slip over the shrouds. The first covers I made I used an off white color thinking it would be better for reflecting the sun which it was but soon started to look very grotty with bird poop, rotted leave debris etc so this time I've gone with forest green which though not good for reflecting heat should be better to hide or blend the muck! Will try and get some photos of the finished covers on the boat next time I'm at the beach.
