| H-18 casting cover for end cap; Main traveler bearing set 2 http://www.hobie.com/au/en/forums/viewtopic.php?f=13&t=10885 |
| Author: | Karen Gibson [ Tue Sep 30, 2008 5:28 pm ] |
| Post subject: | H-18 casting cover for end cap; Main traveler bearing set 2 |
I am looking for a casting cover for the starboard end cap of an H-18 with the nylon screw if possible. I need it in clear, not anodized black. This is the small cover over the spot where a wing might be attached. I also need a bearing set for the main traveler. The H-18 is a 1981 model, and the new bearing sets are too big. The set includes a nylon/plastic ball and a nylon/plastic cylinder - I need the ball the most. Please email me at [email protected] if you have any of these parts you are willing to sell. Thanks, Karen |
| Author: | Zelios [ Wed Oct 01, 2008 12:36 am ] |
| Post subject: | |
Hi how are you The new traveller ball will fit you just may have to unbolt the traveller car when you put it in the track or at least loosen them some times you may just have to tap it into the track and use plenty of lube i like silicon spray it seems to work the best for doing it dont be shy to give the traveller car a whack but you will find that once in the beam it will work no worries its just getting in and out of the beam you will have issues.. its a good thing that it seems tight means your track has not seen much wear... Another option is use two balls no cylinder that works but does have the chance of wearing out when it wears a lil... JJ |
| Author: | Tom Machette [ Wed Oct 01, 2008 6:33 am ] |
| Post subject: | |
http://www.thebeachcats.com/classifieds ... 32/cat/500 |
| Author: | The Dog [ Wed Oct 01, 2008 9:28 am ] |
| Post subject: | |
Hey Karen, I did look for one after you called. I only found one faded out black casting cap - no clear ones. Sorry, Brian |
| Author: | gofastshawn [ Wed Oct 01, 2008 4:40 pm ] |
| Post subject: | |
There is a gentleman out on ebay named stephen that produces new travelor bearing out of top quality delrin.I use them and they are top notch quality and specs are right on the money. hope this helps. shawn 82 h18 #8211 Div3 |
| Author: | MBounds [ Wed Oct 01, 2008 5:01 pm ] |
| Post subject: | |
gofastshawn wrote: There is a gentleman out on ebay named stephen that produces new travelor bearing out of top quality delrin.I use them and they are top notch quality and specs are right on the money.
hope this helps. shawn 82 h18 #8211 Div3 Stephen Cooley - a.k.a. MUST429 on this forum and on Catsailor. He's the HCA Division 5 Chair - you can get his contact info from the HCA website - www.hca-na.org He is the man for all things Hobie 18. |
| Author: | DVL [ Thu Oct 02, 2008 2:04 pm ] |
| Post subject: | |
I purchased his bearings and compaired them to the one new OEM that I had. Exellent quality and size. Perfect reproduction! |
| Author: | hobiefanatic [ Mon Oct 20, 2008 3:19 pm ] |
| Post subject: | |
Stephen's balls work great. His traveling balls. Thanks Stephen for sharing. |
