| which rudder castings to use? & shroud pins? http://www.hobie.com/au/en/forums/viewtopic.php?f=13&t=28390 |
| Author: | petermyers [ Mon Jul 26, 2010 8:14 am ] |
| Post subject: | which rudder castings to use? & shroud pins? |
i have 2 h18s side by side. just got an 82 and want to swap some parts out with the older boat 1 pair is black anodized and has more to the casting the others are not anodized- simpler design which are the preferred ones to use?i understand i will need to do a bit of change of placement of some of the hardware on the transom also- i'm reading that the shroud pins are the major cause of dismasting. are these on the boat or on the mast? easy to change out? thanks for any input |
| Author: | Sailinagin [ Mon Jul 26, 2010 8:45 am ] |
| Post subject: | Re: which rudder castings to use? & shroud pins? |
Quote: also- i'm reading that the shroud pins are the major cause of dismasting. are these on the boat or on the mast? easy to change out? The pins are located at the base of the two sidestays and go through the hull lip and bracket. They are threaded and held on with a nut. If you dont know the age of the pins you should replace them. There are a couple of very good posts on here describing the correct angle of the pin head as well as information about getting the correct improved pin. Search "Demasting - Broken Shroud Annchor Pin" for a good thread. |
