| Installing 1 piece die cast gudgeons http://www.hobie.com/au/en/forums/viewtopic.php?f=13&t=33616 |
| Author: | RobPatt [ Sun Jan 09, 2011 6:09 pm ] |
| Post subject: | Installing 1 piece die cast gudgeons |
talking about the new style... do you need access to inside the hull? is it a easy swap from the old style? are they self tapping screws that come with it..? how do they install? thanks. |
| Author: | MBounds [ Sun Jan 09, 2011 7:59 pm ] |
| Post subject: | Re: Installing 1 piece die cast gudgeons |
RobPatt wrote: talking about the new style... do you need access to inside the hull? No. RobPatt wrote: is it a easy swap from the old style? Depends on your definition of "easy." The holes left by the old gudgeons do not all line up with the new gudgeons, so you'll need to drill and tap new holes & fill the unused ones. It's not hard, but you may not have all the tools to do it. RobPatt wrote: are they self tapping screws that come with it..? I don't think they come with any screws. The ones you want are the 12-24 locking machine screws that Hobie sells. RobPatt wrote: how do they install? Remove the old gudgeons and temporarily install the new with machine screws at the holes that line up. Use the gudgeon as a template to drill the holes that don't line up. Remove the gudgeon, fill the old holes you won't use and tap the new ones. Install the gudgeon with all 8 machine screws and silicone seal. Done. |
| Author: | RobPatt [ Mon Jan 10, 2011 9:27 am ] |
that's enough to let me know whether to 'leap' or 'let it be'. pretty straightforward and no cutting port holes! thanks MBounds. |
| Author: | John Lunn [ Mon Jan 10, 2011 10:38 am ] |
Do I remember something about part of the new style gudgeon has to be ground down? Other than that, sounds simple. |
| Author: | MBounds [ Mon Jan 10, 2011 11:14 am ] |
John Lunn C A wrote: Do I remember something about part of the new style gudgeon has to be ground down? Not the gudgeon, but the lower rudder casting - at extreme steering angles, the lower part of the casting will interfere with the machine screw heads. A high-speed cutter in a Dremel tool will take care of it quickly. |
