| Mast foam plugs http://www.hobie.com/au/en/forums/viewtopic.php?f=13&t=44326 |
| Author: | pelican [ Tue Aug 07, 2012 12:17 pm ] |
| Post subject: | Mast foam plugs |
Can anyone tell me where the foam plugs in the mast are as the previous owner of my boat decided to fill the mast with packing peanuts |
| Author: | MBounds [ Wed Aug 08, 2012 4:24 am ] |
| Post subject: | Re: Mast foam plugs |
They are maybe a foot or so from each end. The masthead one is probably closer and easier to get to. Take the masthead off and you should see it. It's typically covered by a thin aluminum plate and lots of polysulphide caulk. |
| Author: | srm [ Wed Aug 08, 2012 9:11 am ] |
I believe the lower plug on the 18 mast is centered on the diamond wire / rotator bolt. The bolt passes through the plug if I'm not mistaken. sm |
| Author: | pelican [ Wed Aug 08, 2012 12:31 pm ] |
Got a set of new plugs coming in and one aluminum plate. I really hope there is one still in the bottom as it was not in stock with 4 dealers I tried. Any tips on installing the plugs? |
| Author: | MBounds [ Wed Aug 08, 2012 4:16 pm ] |
pelican wrote: Got a set of new plugs coming in and one aluminum plate. I really hope there is one still in the bottom as it was not in stock with 4 dealers I tried. Any tips on installing the plugs? Latex gloves. Seriously. Keeps the caulk off your hands. |
| Author: | ingasguns [ Thu Aug 09, 2012 3:11 pm ] |
there must be one at the diamond wires. on the trailer, i can hear water sloshing inside at that point but not higher up on the mast which on the trailer is lower |
