| Mirage Eclipse Dura Material http://www.hobie.com/au/en/forums/viewtopic.php?f=134&t=68280 |
| Author: | hobiemann [ Sun May 02, 2021 3:31 pm ] |
| Post subject: | Mirage Eclipse Dura Material |
What is the type of plastic used in the eclipse dura I know the top is EVA - is the white bottom HDPE? And is the inside foam core EPS? Thank you |
| Author: | mjohnson009 [ Mon May 03, 2021 3:54 pm ] |
| Post subject: | Re: Mirage Eclipse Dura Material |
The material on the bottom is HDPE High Density Polyethylene I have been successful with using 5 minute epoxy. The bond between the epoxy and the HDPE is not great but is effective. I was recently made aware of a new two part glue called TAP adhesive. I have not tested the TAP but I plan on testing it this week. I will come back to the forum to give my test results later in the week. Her is the link to TAP adhesive- https://www.tapplastics.com/product/rep ... hesive/435 |
