| Corner casting replacement http://www.hobie.com/au/en/forums/viewtopic.php?f=14&t=10097 |
| Author: | mmadge [ Sun Jul 20, 2008 5:54 pm ] |
| Post subject: | Corner casting replacement |
I have to replace the front port corner casting on my hobie 16.If anyone has some insight into this give me some heads up please.Some initial questions I have are as follows. Should I tighten the dolphin striker nut before or after putting in rivits? How important is it to have boat level when putting back together? Any suggestions on a marine sealent to put in castings to reduce squeaking. Does the casting come with bolt hole already drilled? |
| Author: | mmiller [ Mon Jul 21, 2008 3:10 pm ] |
| Post subject: | |
The bolt hole may have to be drilled. The castings are drilled for the smaller / current bolt size. Grease the pylon. Tighten the striker after fully assembling and riveting. Level boat would be good before drilling the pylon bolt hole. |
| Author: | mmadge [ Mon Jul 21, 2008 3:44 pm ] |
| Post subject: | |
Thanks Matt,my boat is a 2006 so it would have the smaller bolt hole.Is there any set # of turns to put on the dolphin striker nut? |
