| Getting Ready to Upgrade to a 16 http://www.hobie.com/au/en/forums/viewtopic.php?f=14&t=1252 |
| Author: | marcusc130 [ Mon Oct 04, 2004 8:19 am ] |
| Post subject: | Getting Ready to Upgrade to a 16 |
Hey everyone! I've finally found a 16 that I think is the right one for me. I'm not sure of the year, but the hulls are solid, the spars are straight, comes witha trailer and beach wheels. It's never seen salt water, but it is dirty as sin because the guy leaves it in the water all summer on a mooring. The jib is missing a few battens. I offered $700, he said $800. This sound like a good buy to you guys? |
| Author: | MBounds [ Mon Oct 04, 2004 10:21 am ] |
| Post subject: | |
What year is it? (Look on the transom - the 3rd and 2nd to last digits of the serial # are the model year - if the serial # is engraved on the pylon, it's a '72 or older) I'd be real careful about a boat that's been kept on a mooring. It could have absorbed a significant amount of water depending on how long it's been there. Not to mention that boats on moorings are never still - they will work themselves to death. I'd look very carefully for fatigue on the rig and the rudder system. |
| Author: | marcusc130 [ Mon Oct 04, 2004 5:12 pm ] |
| Post subject: | |
Ok, thanks for the advise. I will check the year this weekend, he is supposed to take me out for a sail. I thought it would be wise to try it out and see how tight the whole thing is. What's a good way to see if this thing has absorbed alot of water? Maybe you could tell me what the gross weight of a 16 should be. I can stop at the scales on the highway and weigh it. Just a thought Thanks again for the quick response |
| Author: | JaimeZXv.2 [ Mon Oct 04, 2004 5:39 pm ] |
| Post subject: | |
New ones are ~320; I think mine is ~350lbs. You probably wouldn't want one that's much more than that. |
| Author: | marcusc130 [ Thu Oct 07, 2004 12:34 pm ] |
| Post subject: | |
Well, I went and sailed this 16 today, seemed pretty solid. I checked the date and the last 3 digits of the serial number are 80L. I guess this means it was made in december of 1980, which is a strange coincidence since I was made in december of 1980 as well Then I remembered what you all said about the weight. The two of us carried it from the lake through his back yard to the trailer, so I would guess it can't be much more than 300 lbs. Hopefully I got a good deal. |
| Author: | JaimeZXv.2 [ Thu Oct 07, 2004 2:51 pm ] |
| Post subject: | |
That's great, man! Congrats on your purchase. You can get a set of (non class-legal) jib battens pretty cheap from Murray's. I'd also recommend getting the end caps for them. Also, don't silicone them on because they'll pull out, use some epoxy. |
| Author: | marcusc130 [ Sat Oct 09, 2004 7:29 am ] |
| Post subject: | |
I took the 16 out in the big ocean for the first time yesterday. What a difference, it's like being on a rocket ship compared to the 14. Especially in light air (under 15kts). And finally I can tack with no problems. One question I do have. Why do my rudders humm and vibrate. It sounds like a couple of whales mating whenever I get it up to speed. |
| Author: | MBounds [ Sat Oct 09, 2004 7:39 am ] |
| Post subject: | |
