| NEW TO THE HOBIE WAY OF LIFE http://www.hobie.com/au/en/forums/viewtopic.php?f=14&t=1311 |
| Author: | tchristian [ Thu Oct 28, 2004 7:53 pm ] |
| Post subject: | NEW TO THE HOBIE WAY OF LIFE |
I Puchesed a older Hobie 16 1974. Very well kept her previous owner loved her as I'm sure I will do. Todd |
| Author: | MBounds [ Fri Oct 29, 2004 6:54 am ] |
| Post subject: | |
Welcome to the family, Todd! As for your first question, I've never had any problems stepping the mast by myself without any mechanical assistance. If you tie a 10' length of line to the bridle and the other end to the jib halyard shackle, you can hold the mast in place with the jib halyard after you lift the mast up. (Do a search on this forum for "solo mast stepping" and you'll get a ton of free advice.) To bring the shine back on the hulls, you can start with rubbing compound on an electric buffer, but the real secret is to finish it off with 3M "Finesse-It II" polishing compound and an electric buffer. (You can do it manually, but I don't advise it unless you have lots of time and/or need the exercise.) When I was done restoring my '72 H-14, it looked like it had just popped out of the mold! You can get the rubbing compound and Finesse-It at West Marine. To find people to sail with, you should hook up with the folks in Hobie Division 2 here and Fresno Hobie Fleet 62 here. You can check out the latest edition of the Hobie Class News, the class magazine at http://www.hobiecat.com/hobieclass We look forward to seeing you out on the water! |
| Author: | yoh [ Fri Oct 29, 2004 6:59 am ] |
| Post subject: | |
You do not really need any fancy device (besides the step link-but that's a standard) to step the mast solo. Search the forum or follow this link ... http://www.catsailor.com/forums/showfla ... art=1&vc=1 Patrick |
| Author: | fhopper [ Fri Oct 29, 2004 8:36 am ] |
| Post subject: | |
I am a Poly Glow or VertGlass (lovettmarine.com) fan. I would never use rubbing compound on gelcoat. Just use the deoxidizer and then the wipe on coating. It is amazing. I am refinnishing a horrible set of hulls now and will post some pictures after I am done. You can see my problem hulls look terrible. The flash actually makes them look better than they are, I have large areas on each side where the tramp tarp protected the hulls and the blue is much better that the rest of the hulls.
| Author: | widerisbetter [ Fri Oct 29, 2004 12:21 pm ] |
| Post subject: | FYI |
Todd, In case you are REALLY new to sailing and the Forum, we are trying to convince Frank that you have to sail with the boat turned the other side down. He's a sailor, he's just not used to these little toy boats Welcome to the crew PS if you tilt your hulls with the bows down just a few degrees - for example if you are on a flat surface and the hitch end is on the ground (instead of up on the ball), or you are parked with the boat pointed just slightly pointd downhill, you will find that the leverage to raise the mast and to keep it up while the bridle is being attached is greatly increased. With very little foward tilt, the mast will stand by itself. I have never used anything but myself to raise the mast on a 16, and I have always been a little guy (well now I am fat and old and little). At the first sign of storm, we sail !! |
| Author: | JaimeZX [ Fri Oct 29, 2004 2:47 pm ] |
| Post subject: | |
Ref: this thread ( http://www.hobiecat.com/community/viewtopic.php?t=827 ) for solo mast stepping. |
| Author: | tchristian [ Fri Oct 29, 2004 11:43 pm ] |
| Post subject: | MASTS STEPPING |
Ok I am convinced that I need to get out there and do it. Just a bit concerned CIAO Feel like I was born to HOBIE |
| Author: | xanderwess [ Sat Oct 30, 2004 7:36 am ] |
| Post subject: | Don't forget |
Dont forget the mast chip. I am soooo cheap, I use my kids wiffle ball golf balls and cut them in half. They fit perfect. Stick one of thise in the mast base before you tip the mast. |
| Author: | JaimeZX [ Sun Oct 31, 2004 7:41 am ] |
| Post subject: | |
Circles cut from the lid of a peanut butter jar or the cap from a Gatorade bottle work too. |
