| 1981 vs. 1984 Hobie 16 http://www.hobie.com/au/en/forums/viewtopic.php?f=14&t=13867 |
| Author: | petersdj [ Wed Aug 19, 2009 8:19 am ] |
| Post subject: | 1981 vs. 1984 Hobie 16 |
Newbie here. I'm looking buying my first H16, and there are three 81 models and one 84 model. The owner of the 84 says that Hobie changed the "weighting" on the 84 model and that was the best year. What does he mean and is he correct? Thanks! Dan |
| Author: | mmiller [ Wed Aug 19, 2009 8:22 am ] |
| Post subject: | Re: 1981 vs. 1984 Hobie 16 |
The boats were at 340 lbs or more until 1984. We lightened the boat to 320 in 1984 and still build it at that weight. |
| Author: | petersdj [ Wed Aug 19, 2009 8:34 am ] |
Oh total weight. I thought it was some balance weight. Does that 20lbs really make a difference? Are there any other design changes that would really discriminate an 81 vs an 84? Thanks again, Dan |
| Author: | mmiller [ Wed Aug 19, 2009 8:37 am ] |
In 1982 there were some changes to the mast step and mast base along with changes to the wire lengths. This allows more mast rake. The newer boats sail better, point higher. The '84 will be faster most likely. But this is all about racing. If you are sailing more recreational... not a big difference. |
| Author: | MBounds [ Wed Aug 19, 2009 8:51 am ] |
Biggest difference (and worth it in my opinion) - the 1984 will have rake adjustable rudder castings, whereas the others will not. |
| Author: | LindaP [ Wed Aug 19, 2009 9:13 am ] |
MBounds wrote: Biggest difference (and worth it in my opinion) - the 1984 will have rake adjustable rudder castings, whereas the others will not. Can you add the rake adjustable rudder castings to older boats?
| Author: | Tom Machette [ Wed Aug 19, 2009 10:57 am ] |
yeah, you just have to buy new castings. |
| Author: | MBounds [ Wed Aug 19, 2009 11:12 am ] |
Tom Machette wrote: yeah, you just have to buy new castings. $$$$$ There, fixed it for you, Tom. |
| Author: | Tom Machette [ Wed Aug 19, 2009 12:08 pm ] |
Thanks Matt, that's what I meant to say. |
| Author: | AntonLargiader [ Mon Sep 28, 2009 12:31 pm ] |
mmiller wrote: In 1982 there were some changes to the mast step and mast base along with changes to the wire lengths. This allows more mast rake. What sort of problems are there using the old base/step with more mast rake? Will it not rotate as well? |
| Author: | MBounds [ Mon Sep 28, 2009 1:47 pm ] |
AntonLargiader wrote: mmiller wrote: In 1982 there were some changes to the mast step and mast base along with changes to the wire lengths. This allows more mast rake. What sort of problems are there using the old base/step with more mast rake? Will it not rotate as well? It won't rotate at all. The stepping nub on the aft end of the mast base will interfere with the aft shoulders of the mast step. |
| Author: | AntonLargiader [ Mon Sep 28, 2009 2:29 pm ] |
Sounds like I'll have to step the mast and play around with it. I think I have original step and base with new standing rigging. However I've never raked back all that much because I have the stacked mainsheet blocks. I'm going to convert those to the nonstacked configuration, so maybe rake will become an issue where it now is not. |
