| My mast is missing a bolt http://www.hobie.com/au/en/forums/viewtopic.php?f=14&t=13942 |
| Author: | broken [ Fri Aug 21, 2009 3:26 pm ] |
| Post subject: | My mast is missing a bolt |
There is a bolt that holds the metal part of the mast to the fiberglass part. ( I assume it's fiberglass or some non-conductive material) Mine is missing and I can't seem to locate it on the Hobie part diagram. is this something I can buy and if so where? |
| Author: | mmiller [ Fri Aug 21, 2009 3:32 pm ] |
| Post subject: | Re: My mast is missing a bolt |
The original 1985 CompTips had a bolt. That is no longer available. You can use anything there. Should be epoxied in place at the minimum and bolted / riveted. |
| Author: | broken [ Fri Aug 21, 2009 7:44 pm ] |
thank you |
| Author: | sharkfeed2000 [ Fri Aug 21, 2009 8:41 pm ] |
I have one of the early comptip on my stars and stripe h 16 and it has what looks like an end to end polt such as the one that comes in the rudder cam rebuild kiy only larger. I make sure that i check it before everytime i go out on the water |
| Author: | sharkfeed2000 [ Fri Aug 21, 2009 8:42 pm ] |
I have one of the early comptips on my stars and stripes h 16 and it has what looks like an end to end bolt such as the one that comes in the rudder cam rebuild kit only larger. I make sure that I check it before everytime i go out on the water |
| Author: | mhol59 [ Fri Aug 03, 2018 2:18 pm ] |
Can anyone give the specs of the bolt that was originally installed in the 1985 Comptip mast? Length size type ? Believe it was a sex bolt? |
| Author: | mmiller [ Fri Aug 03, 2018 2:22 pm ] |
Was a sister screw... flat head on each end. One long clear through was female threaded. Then a short standard flat head screw. I don;t have the specs. Better to glue in place with epoxy and add some stainless rivets for good measure. |
