| SOFT SPOTS? HELP!!! http://www.hobie.com/au/en/forums/viewtopic.php?f=14&t=1409 |
Page 1 of 2 |
| Author: | tchristian [ Sun Dec 19, 2004 8:03 pm ] |
| Post subject: | SOFT SPOTS? HELP!!! |
I was out messing around and I noticed what apears to be a soft spot The other pics are a before and after this is the before. can't wairt for spring. Thanks Todd C goto Zatara folder or you can see my wife's doll hobbie too. http://photos.yahoo.com/[email protected] |
| Author: | JaimeZX [ Sun Dec 19, 2004 9:54 pm ] |
| Post subject: | Re: SOFT SPOTS? HELP!!! |
tchristian wrote: I was out messing around and I noticed what apears to be a soft spot
The other pics are a before and after this is the before. can't wait for spring! Todd, could you be more specific as to where the soft spots are? In the deck or in the hull? The method for dealing with them will depend. |
| Author: | tchristian [ Sun Dec 19, 2004 9:58 pm ] |
| Post subject: | |
Jim It is on the deck, I linked a pic so you could look at it. Its froward of the trap on the port Hull. let me know if you can't get to the Pic's and I'll e-mail them to you Todd |
| Author: | JaimeZX [ Mon Dec 20, 2004 8:50 pm ] |
| Post subject: | |
Yeah buddy, they're not showing up. I quoted you to see if I could find a link to the images, but it didn't work either. If it's in the deck there is a procedure in place (ref: http://www.hobiecat.com/support/tech/delam.html ) to fix it. There are a number of threads including pictures where people have taken care of this issue. Good luck! |
| Author: | tchristian [ Mon Dec 20, 2004 9:16 pm ] |
| Post subject: | |
Many thanks, Do you know how deep to drill beween the glass? Is it a good idea to have the boat upside down? I read somthing from Matt Miller about this just not sure if this is what he was talking about. Hope you have a great HOBIE HOLIDAYS. Todd C |
| Author: | mmiller [ Tue Dec 21, 2004 11:18 am ] |
| Post subject: | How deep? |
How deep? Through the top layer of glass, clear through the foam and STOP at the inner glass layer. |
| Author: | mjb [ Thu Dec 23, 2004 9:12 am ] |
| Post subject: | |
Todd, The easiest way to avoid drilling through the inner layer is to make a stop out of a scrap piece of 2x4. All you need to do is drill a hole through the 2x4 and adjust your drill bit so it extends just barely beyond the 2x4. Drill your first test hole with the 2x4 (stop) on the drill bit. Keep extending the bit beyond the stop until you reach the correct depth. You can then use the stop to drill all the holes you want without drilling through the inner layer. Good Luck MJB |
| Author: | widerisbetter [ Thu Dec 23, 2004 11:03 am ] |
| Post subject: | cool idea mjb |
Many of us look for alternate ways to do things either out of necessity of the moment or simply out of looking for affordable options- THAT is a good one. I use a "stop collar" that came from Sears (I think) for drilling specific depths- they run $5- $10. Before I bought the stop I used to wrap about a 1/4 inch thick layer of 1/2 inch masking tape at the desired distance up the drill bit. You would be surprised how long that lasts and how well it works. Good Luck.... |
| Author: | mattnd54 [ Thu Dec 23, 2004 7:15 pm ] |
| Post subject: | |
Its far simpler than they are making it out to be. I drilled quite a few holes in my hull without anything besides the bit and the drill and I never drilled into the second layer. Just be careful, don't lean on the drill and you will be just fine. |
| Author: | tchristian [ Sun Jan 02, 2005 11:03 pm ] |
| Post subject: | |
Jim and Stephen, Everthing went well except for one thing I miss judged two holes out side the delam area. Thinking of mixing polyester resin with yellow to fill the holes. They are dry, hand held drill bit fits exactly where I drilled Todd |
| Author: | JaimeZX [ Mon Jan 03, 2005 10:54 am ] |
| Post subject: | |
If it's solid then sounds like you did a good job! Just fill those two holes with dyed polyesther or epoxy and you should be fine. Jim |
| Author: | Mitch [ Tue Jan 25, 2005 2:26 pm ] |
| Post subject: | Laminiating resin |
According to the fix at http://www.hobiecat.com/support/tech/delam.html , I'm to inject with laminating resin. Is Git Rot the stuff to use? I mentioned same my dealer and he thought Git Rot was only for plywood repairs. Where can I obtain it or better 'laminating resin'? Mitch |
| Author: | Genmar Star [ Tue Jan 25, 2005 2:54 pm ] |
| Post subject: | |
You dont need to use "Git Rot". Any polyester resin without wax (laminating resin) or epoxy resin will be fine. I would recommend West System for this repair. Any boat supply should stock this. |
| Author: | mmiller [ Tue Jan 25, 2005 2:55 pm ] |
| Post subject: | Git Rot |
Git Rot is still my favorite. I did a repair with it in the mid 80's and I know the boat is still solid today. The stuff is just a type of epoxy. The benefit here is that it doesn't set up too hard and is easy to work with. http://www.google.com/search?hl=en&ie=UTF-8&oe=UTF-8&q=Git+Rot |
| Author: | Genmar Star [ Tue Jan 25, 2005 3:09 pm ] |
| Post subject: | |
Its basically thined out resin. The idea being it is supposed to penetrate better. Who knows? |
