| Help re H-16 bow tang removal http://www.hobie.com/au/en/forums/viewtopic.php?f=14&t=14588 |
| Author: | TexKat [ Tue Sep 08, 2009 9:53 am ] |
| Post subject: | Help re H-16 bow tang removal |
Any tips on removing bow tang nut/bolt to install new bridle wires? Boat is an 86 model and bridle wires are in need of new ones of course. It's hard to get a full seat on nut with socket without chipping some gelcoat in order to do so. Also it's difficult to hold a bite with a common screwdriver on the bolt head. I hope someone can give me a couple tips to make this task maybe a little easier! Another thought, wouldn't a hex head bolt be easier to deal with in the future than a panhead screwdriver applied type? Thanx ahead for any suggestions here. |
| Author: | mmiller [ Tue Sep 08, 2009 12:24 pm ] |
| Post subject: | Re: Help re H-16 bow tang removal |
Try Vise Grips on the nut. Hex heads have sharp edges. The nut does not require significant tensioning, so the slot / pan head works. |
| Author: | sunvista [ Tue Sep 08, 2009 3:53 pm ] |
Yeah they are a bear to get off if your boat has spent any time in salt water. I had to use an impact driver (not recommended) so I replaced mine with hex bolts when I finally freed them up. I use hex bolts on the crossbar end adjusters and rudder arm slide plates too for the same reason. You just can't get enough torque with a screwdriver on a salt water seized bolt or screw. I'm not sure the edges on a hex bolt are going to be any more dangerous than anything else. Everything on the boat that I land on, am thrown against or bounce off of hurts anyway. |
| Author: | Tri_X_Troll [ Tue Sep 08, 2009 4:04 pm ] |
PB blaster? |
| Author: | TexKat [ Tue Sep 08, 2009 4:47 pm ] |
Fixin to attack it again. Thanks for suggestions. PB is most definitely a must! |
| Author: | MBounds [ Tue Sep 08, 2009 5:08 pm ] |
If it won't come loose, then cut the head off with a Dremel tool. You weren't planning to re-use it after all the abuse you're giving it, were you? |
| Author: | TexKat [ Tue Sep 08, 2009 5:30 pm ] |
MBounds wrote: If it won't come loose, then cut the head off with a Dremel tool. You weren't planning to re-use it after all the abuse you're giving it, were you? I honestly believe that's the easy and smart approach. No, I wasn't intending to reuse regardless of possibly no battle damage. Thanks Matt |
| Author: | MBounds [ Tue Sep 08, 2009 6:14 pm ] |
TexKat wrote: MBounds wrote: If it won't come loose, then cut the head off with a Dremel tool. You weren't planning to re-use it after all the abuse you're giving it, were you? I honestly believe that's the easy and smart approach. No, I wasn't intending to reuse regardless of possibly no battle damage. Thanks Matt Just watch the heat build-up. Wouldn't want to start a fire or anything like that. |
