| Gooseneck Bearing Kit http://www.hobie.com/au/en/forums/viewtopic.php?f=14&t=15577 |
| Author: | jimw00d [ Fri Oct 02, 2009 10:18 am ] |
| Post subject: | Gooseneck Bearing Kit |
I purchase a gooseneck bearing kit for my HC16 from Murrays, part number 12-2050. URL: http://www.murrays.com/archive/26.pdf It arrived today and I went straight to the boat to attach it. However, I noticed that the two plastic bearings are far too big for the slide holes. I guess to get them in I would have to give them more than a tap with a hammer and in doing so I would probably sheer off some of the bearings' plastic. I am pretty sure my gooseneck is a factory standard and I so I don't quite understand what I am supposed to do here. Thanks |
| Author: | Bill 404 [ Fri Oct 02, 2009 11:04 am ] |
| Post subject: | Re: Gooseneck Bearing Kit |
That the way I put my in,with a hammer and they do fit tight...........and that's nice |
| Author: | drej [ Fri Oct 02, 2009 6:18 pm ] |
I hope I am understanding your question correctly. Yes, you may need to tap the bearings into the top and bottom of the gooseneck with a hammer. When in correctly, the outer part of each bearing should actually be the same size, if not a little larger, than the diameter of the gooseneck itself - allowing the gooseneck to move easily in the sail track. The screw then holds it all in place. Tapping it in with a hammer shouldn't take away any of the portion of the bearing that is useable. Good luck! |
| Author: | Rojoyinc [ Sat Oct 03, 2009 8:11 am ] |
I had just noticed this in the catalog and have tought about getting one. On my newer boat I can't get the gooseneck in the slot and slid down easily... I have to really fiddle with it - OR - I sail for a few minutes and then it drops down... this bearing should ease that problem? making it easier to slide down into the track? |
