| Some more shroud questions http://www.hobie.com/au/en/forums/viewtopic.php?f=14&t=1564 |
| Author: | Genmar Star [ Mon Feb 21, 2005 4:38 pm ] |
| Post subject: | Some more shroud questions |
I will be adding another chainplate to my forestay for more rake and was under the impression I needed to order shrouds for a 17 because they were shorter, but according to the shroud sizes I saw on this site they are the same 18'11". ????? Also ,should I go ahead and replace the jib luff wire or does a new jib come with one. If I do replace the jib luff wire I noticed two different sizes with about a foot in difference. Which one should I get? |
| Author: | sunjammers [ Mon Feb 21, 2005 11:36 pm ] |
| Post subject: | |
Hobie 16 and Hobie 17 side shrouds are the same. If you are wanting to replace all of your wires get a H16 wire set, it comes with all of your standing rigging and single trap, new jib halyard....the works! Your new jib will come with a luff wire, not sure about putting a new one in, just use your old on as a templet if you are going to make one, but unless it is broken I would leave it along, remember your jib luff wire actually holds all the tension on a H16. Hope this helps, the wire set will run less that $190 bucks and is 5/32 black coated, it is defiantly the way to go! Thanks, Brad Stephens www.sunjammers.com Authorized Hobie/Vanguard/Hunter Dealer Hobie Division 15 Chairman [email protected] 850-235-2281 Panama City Beach, FL |
| Author: | Joby1knobi [ Tue Feb 22, 2005 9:57 am ] |
| Post subject: | |
May I also add this: get the shrouds from a Hobie Dealer. Last year I ordered shrouds from Murray's and they were a little over an inch longer than the Hobie stock shrouds I was replacing (off of a 2000 model year 16). When I got the Hobie factory replacements, they were an exact match. |
