| Mast Base Adhesive http://www.hobie.com/au/en/forums/viewtopic.php?f=14&t=1995 |
| Author: | royal [ Sat Jul 02, 2005 5:12 am ] |
| Post subject: | Mast Base Adhesive |
I have to replace the mast base. Do I need to use some sort of adhesive in addition to riveting? If so, what type of adhesive should I use. Also, I had to replace the cheek block on the mast. When I removed the rivets, the inside part of the rivets fell through the holes and are now rolling around inside the mast. I don't really want to break the seals on the mast to get them out. Is this going to be a problem in the future? Thanks, Joe |
| Author: | MBounds [ Sat Jul 02, 2005 7:40 pm ] |
| Post subject: | |
Short answer to both questions: No. On #2 it's no only if you don't mind the rattle. |
| Author: | JaimeZX [ Sun Jul 03, 2005 2:29 pm ] |
| Post subject: | |
Maybe he can switch masts with Jerome "Rattle 'n' Hum" Vaughan. |
| Author: | yoh [ Tue Jul 05, 2005 10:55 am ] |
| Post subject: | |
Rivets... No they will move around inside the mast (especially when you step the mast). They will not cause any issues. |
