| Strange Serial Number? http://www.hobie.com/au/en/forums/viewtopic.php?f=14&t=254 |
| Author: | jamie [ Mon Jul 07, 2003 5:50 pm ] |
| Post subject: | Strange Serial Number? |
I am looking at purchasing an '82 Hobie 16. However, the serial number format seems to be at odds with the way hobie says they should appear. I can't find anymore info on Hobie S/ns anywhere. On this hobie it reads CCMQ6086M 82F, with an NI or N1 or NL on a second line under the 60. Is this a standard format for 1982 hobies?? What's up? Any ideas? The sail number is 65xxx, which seems right for an 82, right? |
| Author: | sunjammers [ Mon Jul 07, 2003 8:19 pm ] |
| Post subject: | |
Your boat is a 1982. Make sure that the hulls are solid and everything else seams to be there Let me know if you have any questions, there is nothing worse than buying a boat for a few hundred dollars only to find out it need $1,000 worth of parts and $1000 worth of glass work, Not saying I don't like to sell parts just normally the parts are more than the boat is worth! Thanks, Brad Stephens Authorized Hobie/Vanguard Dealer www.sunjammers.com [email protected] 850-235-2281 Panama City Beach, FL |
| Author: | MBounds [ Mon Jul 14, 2003 7:35 pm ] |
| Post subject: | Serial #'s |
What you may have is either a replacement hull (which are required to have the same serial # as the other hull). Do the hulls have the same amount of wear / fading / discoloration? If not, what happened to the original hull and what else broke? The 65xxx sail is definitely in line with it's age. My third 16 was an '84 with an '83 sail - #74722. |
