| Need manual for Mast Stepper system http://www.hobie.com/au/en/forums/viewtopic.php?f=14&t=28090 |
| Author: | leverjk [ Mon Jul 19, 2010 5:58 am ] |
| Post subject: | Need manual for Mast Stepper system |
I bought a used Hobie that has a mast stepper system. I do not have the foot component. A manual or ideas about replacing foot would be appreciated. Thanks, Joe |
| Author: | Hobiesailer8 [ Sun Jul 25, 2010 8:56 pm ] |
| Post subject: | Re: Need manual for Mast Stepper system |
i am having the same problem on mine, but i'm pretty sure if you go to a hobie dealer that you can order a new one... |
| Author: | rattle 'n hum [ Mon Jul 26, 2010 10:40 am ] |
I have instructions for the EZ Step. Is that what you need? If so, send a note to jv1234_99 <at> yahoo <dot> com. |
| Author: | tchilds [ Mon Jul 26, 2010 10:00 pm ] |
I put the pin in, then lift the mast base to the up position. Step the mast (will pop into up position violently if you didn't already set it). Next, step the mast carefully lowering the ball into socket as you do this. If you step the mast too far, without lowering the ball into socket first, you will break the rivets in bottom of mast and bend the bolt in the little ez stepper thing. Kind of a pita to replace the rivets so be careful. My 140lb friend broke my mast w/out much effort... |
| Author: | leverjk [ Tue Aug 03, 2010 4:16 am ] |
Jerome, Unable to get your email to deliver. Joe |
| Author: | rattle 'n hum [ Tue Aug 03, 2010 10:39 am ] |
leverjk wrote: Jerome, Unable to get your email to deliver. Joe I uploaded the manual here: http://tinyurl.com/3azg3ae [email protected] |
| Author: | leverjk [ Wed Aug 04, 2010 3:55 am ] |
Thanks Jerome for your help. |
| Author: | rattle 'n hum [ Wed Aug 04, 2010 10:53 am ] |
No problem, mon! |
