| Is the righting system with the shockcord..... http://www.hobie.com/au/en/forums/viewtopic.php?f=14&t=28886 |
| Author: | ECU_Sailor [ Wed Aug 04, 2010 11:08 am ] |
| Post subject: | Is the righting system with the shockcord..... |
tied to the line that is run through blocks and mounted through the hulls a typical hawaiian style? Or was this something that the previous owner just rigged up?? |
| Author: | sunvista [ Wed Aug 04, 2010 11:24 am ] |
| Post subject: | Re: Is the righting system with the shockcord..... |
I've never seen a righting system that ran through blocks unless using a righting bag. You might have to post a photo. |
| Author: | MBounds [ Wed Aug 04, 2010 11:52 am ] |
Short answer is yes. The there are two types of "snap back" righting lines. One uses a large, hollow core line that has bungee running inside it. The other uses a solid line (a lot of us used old mainsheets) with a bungee that attaches to the dolphin striker, runs back to a block tied to the traveller eyestrap, then forward to a terminating block that the actual righting line ran through. |
| Author: | Roy [ Fri Aug 06, 2010 9:16 am ] |
I saw on this form somewhere some nice pictures of this system? |
| Author: | ET Hobie guy [ Fri Aug 06, 2010 6:07 pm ] |
The Hawaiian Righting system with the blocks can be seen in a diagram on page 18 of the parts and accessories catalog |
