| Rotator brackets to fit H16 mast . . . http://www.hobie.com/au/en/forums/viewtopic.php?f=14&t=2923 |
| Author: | DavidBell47 [ Thu Jan 19, 2006 11:10 pm ] |
| Post subject: | Rotator brackets to fit H16 mast . . . |
I know it's not class legal but has anyone here ever used a mast rotation control arm on a H16? If so, what type of mounting brackets were attached to the mast? Would appreciate any info. Thanks, David |
| Author: | DougHobie17 [ Fri Jan 20, 2006 8:56 am ] |
| Post subject: | mast Rotator |
I used a bracket for a boomless shaped like a V I got from Murrays on my Hobie 17. Ran a block system with a cleat to the boom. Works great. If confused call me. Doug Snell 281-326-2702 |
| Author: | DavidBell47 [ Fri Jan 20, 2006 9:31 am ] |
| Post subject: | |
Thanks for the input Doug. I have found the rotation arm that you were referring to at Murray's. What I need is the two mounting brackets that are riveted to each side of the mast that rotation arm is connected to. I think mast on your 17 might already come with the brackets on it. Any ideas ? David |
| Author: | DougHobie17 [ Fri Jan 20, 2006 9:41 am ] |
| Post subject: | Brackets |
I just took off my old arm and bolted new one on. Call Murrays on there 800 number. They have always been VERY helpful to me. If they don't have them, I am sure they can send you in right direction. Good luck. Doug |
| Author: | DavidBell47 [ Fri Jan 20, 2006 10:29 am ] |
| Post subject: | |
Thanks again Doug, Does the bolt go all the way through the mast ?? |
| Author: | DougHobie17 [ Fri Jan 20, 2006 10:39 am ] |
| Post subject: | Bolt |
David: Yes, just like all the mast rotator arm do. Murrays should help you. Steve has always be great to me. Good luck. I stared on a 16. good boat, just got tired of always fighting to find a crew. Hope to get a Nacra A2 soon. Good A class fleet around here at Houston Yacht Club. Register and go on our site. www.tcdyc.com. Good forum. Doug |
| Author: | Hobie Nick [ Fri Jan 20, 2006 11:21 am ] |
| Post subject: | |
It would eb a good idea to spport the inside walls of the mast where the bolt passes though. Either put a tube between the sides of the mast or get a fully threaded bolt and put a nylock nut on both of the inside walls. |
