| Spinnaker for H16 - What size??? http://www.hobie.com/au/en/forums/viewtopic.php?f=14&t=30366 |
Page 1 of 3 |
| Author: | Jman6631 [ Wed Aug 25, 2010 6:07 am ] |
| Post subject: | Spinnaker for H16 - What size??? |
I am planning to add a spinnaker to my 16. I found a spinnaker sail that came from a 24ft Seafarer; Does anyone know what the sail dimensions are for a spinnaker on a H16? This one's probably over sized but I'm not sure where to start. Any input on size ranges would be very helpful. Thanks in advance! |
| Author: | MBounds [ Wed Aug 25, 2010 7:16 am ] |
| Post subject: | Re: Spinnaker for H16 - What size??? |
A spinnaker for a monohull is entirely the wrong shape for a catamaran. Most monohull spinnakers are symmetrical and full and meant for sailing dead downwind. Catamaran spinnakers are assymetrical and flat and meant for VMG reaching at ~45 degrees apparent wind. They're more like a large jib sail than a conventional spinnaker. What you have is completely useless on a Hobie 16. The Hobie 16 spinnaker is quite small. |
| Author: | sunvista [ Wed Aug 25, 2010 7:17 am ] |
My buddy just put a spinnaker on his boat. I think he said it was 12 or 13 meters square. We're having a blast! He is already talking about a larger one now. |
| Author: | tchilds [ Wed Aug 25, 2010 8:41 am ] |
This should get you started in the right direction. http://www.catsailor.com/forums/ubbthre ... ber=179150 |
| Author: | Jman6631 [ Wed Aug 25, 2010 9:04 am ] |
...and this is exactly why I come to the forum first. MBounds, you are the man; Sunvista, you give me hope; Tchilds, the devil's in the details. THANKS to all! |
| Author: | sunvista [ Wed Aug 25, 2010 12:41 pm ] |
I think the H16 spins are typically smaller for a reason. The mast tang is just pop riveted into plastic with the comp tip. If you have an older all alum mast you're golden. |
| Author: | Jman6631 [ Wed Aug 25, 2010 12:51 pm ] |
I do actually, I have the one piece extrusion. WooHoo. Have you (or anybody) seen or heard of The Hooter: http://www.catsailor.com/bestof_articles/Hooter.html Thoughts? Opinions? Concerns? |
| Author: | sunvista [ Wed Aug 25, 2010 2:24 pm ] |
Saw one on a H14 a couple years ago. Don't remember much detail though. |
| Author: | sunvista [ Thu Aug 26, 2010 5:57 am ] |
I double checked the spinnaker size. It's 128 square feet. Everything is totally home grown. He made it with an industrial sewing machine and a $300 sail kit. The rest was modeled from the cat sailor link above, the Hobie Europe instructions and a lot of scientific guesswork (trial and error). Boom from a sawed off wind surfer mast. Piece parts (spin lock cleats, ratchet blocks, sheet rope etc) all begged, borrowed and purchased. We had a Hobie Tiger and a Nacra F18 to look at so we weren't flying totally blind. |
| Author: | Jman6631 [ Thu Aug 26, 2010 9:03 am ] |
Thanks Sunvista! Sound's exactly like the process I am engaging! One bummer is that a couple of years ago I "freecycled" a windsurfer that I had received via freecycle myself. Would've, could've, should've..... |
| Author: | splashTX [ Wed Dec 08, 2010 9:12 am ] |
Jman6631 did you put together a DIY Spinnaker setup for your Hobie 16? I would like to try and do the same thing. If so, please tell us how? Exact sail size too. Did you go with a windsurfer mast for the pole? I'm eager to add on to my Hobie 16 Thanks, Mike |
| Author: | DavidBell47 [ Wed Dec 08, 2010 10:33 pm ] |
Luff = 19.5 ft Foot = 8.75 ft Leach = 17.25 ft |
| Author: | splashTX [ Thu Dec 09, 2010 7:14 am ] |
DavidBell47 wrote: Luff = 19.5 ft Foot = 8.75 ft Leach = 17.25 ft Thanks David, I found the Hobie 16 Spinnaker on catsailor at the following sizes: Luff = 21.5' Foot = 9' Leech = 18.7' 2' longer luff? I wonder why the difference. Mike |
| Author: | Sail Revolution [ Thu Dec 09, 2010 10:08 am ] |
MG dimension is critical. |
| Author: | splashTX [ Wed Jan 05, 2011 4:49 pm ] |
Surf City Catamarans wrote: MG dimension is critical. Do You have a MG Dimension? What is a MG Dimension? Also, any one now what size and length the lines are for a midpole snuffer system? Halyard/dousing line (loop)? Tack Line? Spinnaker Sheet (Loop)? Would 40mm carbo and auto ratcheting blocks be suitable for the sheets? What size blocks for the halyard & tack lines? I'm gathering all my blocks now. I just purchased the aluminum pipe that will be my pole. Thanks, |
| Page 1 of 3 | All times are UTC - 8 hours [ DST ] |
