| hobie modifications http://www.hobie.com/au/en/forums/viewtopic.php?f=14&t=3125 |
| Author: | Chas Man [ Tue Feb 28, 2006 3:10 pm ] |
| Post subject: | hobie modifications |
I saw this on another site. Any thoughts? "I’m on my 3rd Hobie 16 and have made a few modifications to avoid having the thing fall apart on me sailing it balls-to-the-walls. Both hulls developed cracks inside and just forward of the forward tramp support post(s) when cranking down the mainsheet sailing tight to windward. My fix for this was a section of galvanized fence piping and 2 bolt hole caps bolted across the front of the bows in the same holes used by the 2 forestays. This keeps the bows at the same width and works as hand holds when pulling the boat around on the beach. I also added a second sidestay to each side and tension each pair share the load equally. On the 2nd Hobie I had a welder weld a second stainless dolphin striker support and then added a second dolphin striker in tandem with the existing one. My first Hobie fell apart when the striker parted." These 3 mods beef the boat up a bit. I have sailed my boat hard for a number of years and it has held up well, but I worry about the single striker - if it fails and the load on the main isn't eased ASAP, the tramp supports will break." |
| Author: | MBounds [ Tue Feb 28, 2006 5:52 pm ] |
| Post subject: | |
Overkill. Unless you've got 500 lbs of beef on the wire. In 33 years of playing with these toys, I've never seen a dolphin striker fail. I have seen bows break off, but that was because there was un-repaired delamination.
The beer can in the hull is a nice touch. |
| Author: | JaimeZX [ Wed Mar 01, 2006 8:14 am ] |
| Post subject: | |
For the shrouds, IMHO it'd be easier & just as effective to add another layer of glass inside the hull/deck joint lip and get a longer rod for the shroud connector to bolt through. If you get the heavier-duty shrouds it should be PLENTY strong. |
