| Mast Base Repair http://www.hobie.com/au/en/forums/viewtopic.php?f=14&t=33189 |
| Author: | GDavies [ Sun Nov 14, 2010 8:53 am ] |
| Post subject: | Mast Base Repair |
I have read previous posts on repair/replacement of mast base. I did not note if you should or should not use rivet caps in this application. I have read in this forum that rivet caps should be used any time you penetrate the mast, however this is below the internal mast plug. ????? |
| Author: | ericweller [ Mon Nov 15, 2010 9:51 am ] |
| Post subject: | Re: Mast Base Repair |
Caps are not necessary for the mast base. That area of the mast gets wet by design. The mast base does not form a perfect seal to the mast. |
