| Q. In the forward crossmember.... http://www.hobie.com/au/en/forums/viewtopic.php?f=14&t=35729 |
| Author: | Johnnymoto [ Mon May 23, 2011 8:10 am ] |
| Post subject: | Q. In the forward crossmember.... |
In the forward crossmember where the gib cleats are, inside the rail channel, there are two screws that prevent the gib cleats/carts to go any further inboard than half way ( one screw on each side half way into the channel ) Is this a "homemade-mod" ? Is there a special part that goes in there ? These screws seem improperly mounted, just screwed into the beam. Anticipated thanks !!! |
| Author: | Sail Revolution [ Mon May 23, 2011 8:17 am ] |
| Post subject: | Re: Q. In the forward crossmember.... |
Johnnymoto wrote: In the forward crossmember where the gib cleats are, inside the rail channel, there are two screws that prevent the gib cleats/carts to go any further inboard than half way ( one screw on each side half way into the channel ) Is this a "homemade-mod" ? Is there a special part that goes in there ? These screws seem improperly mounted, just screwed into the beam. Anticipated thanks !!! There should be a little plastic piece that fits into your jib track with one screw through the center and into the cross bar.
| Author: | Johnnymoto [ Mon May 23, 2011 8:24 am ] |
THANKS SURF CITY !!!! The bar on my H16 is different from the one on the picture, mine has the channel embeded in the bar. I will find a piece of hard plastic or teflon and shape it and install that instead of the odd looking screws it has now. THANKS AGAIN !!!!! |
| Author: | Sail Revolution [ Mon May 23, 2011 8:35 am ] |
Copy. That's a Getaway fwd x bar, same style as the older 16. Can't find a pic, but this might help. There should be a little plastic cylinder with a single screw through it and threaded into the x bar used as a stop. viewtopic.php?f=14&t=12627&view=previous |
| Author: | Johnnymoto [ Mon May 23, 2011 8:55 am ] |
THANKS SURF CITY !!! I have an idea now !!!! |
