| Rough day on the water http://www.hobie.com/au/en/forums/viewtopic.php?f=14&t=37902 |
| Author: | Vince42 [ Tue Aug 23, 2011 8:13 pm ] |
| Post subject: | Rough day on the water |
I recently purchased a hobie 16, and i decided to capsize it. I have a float, but the three people I had on board and I couldnt get her back up. I have a righting line, but it just didnt help. We were eventually helped out by a nearby power boater, but what should I do? |
| Author: | Jman6631 [ Wed Aug 24, 2011 10:04 am ] |
| Post subject: | Re: Rough day on the water |
First verify that you followed the correct process: 1) Uncleat jib and main 2) Get her mast turned ~45 degrees into the wind, THEN pull My first capsize I couldn't get her mast turned into the wind as the wind and current were fighting me hard. Ended up needing a good sam sailboat to assist. |
| Author: | jsloan999 [ Wed Aug 24, 2011 12:10 pm ] |
Uncleat sheets, Mast 45 degrees to the wind. Standing on the lower hull, you and crew lean back holding the righting line as close to the water as you can with out being in the water - and start to rock the hull you are standing on up and down. This will coax the mast to slowly rise out of the water. |
| Author: | fastcat [ Wed Aug 24, 2011 12:31 pm ] |
Make sure the mast is water tight (does it make a sloshing sound?). To turn the boat into the wind stand more toward the bows and it should round up. Also the main traveler should be all the way out. |
| Author: | pilot1 [ Mon Aug 29, 2011 12:43 pm ] |
You all forgot to mention that in order to get the mast 45 degrees to the wind that the easiest way to do that is to stand on the nose(bow) of the hull that is in the water, this will make the trampoline use the wind to turn the boat in the right direction. THen do the above what all the others said. Def. check that your mast doesnt have a leak..... I am 6'4" built like a football player 240 pounds ex Navy, and I can right my hobie everytime even WITH a leaky mast:) |
| Author: | fastcat [ Mon Aug 29, 2011 3:38 pm ] |
Quote: You all forgot to mention that in order to get the mast 45 degrees to the wind that the easiest way to do that is to stand on the nose(bow) of the hull that is in the water Actually I did say that Quote: To turn the boat into the wind stand more toward the bows and it should round up. Just not as clearly. |
| Author: | newsreader [ Mon Aug 29, 2011 6:30 pm ] |
But, can you still do that if the boat is turtled ? pilot1 wrote: and I can right my hobie everytime even WITH a leaky mast:)
| Author: | caseycasey [ Tue Aug 30, 2011 6:40 pm ] |
Check your technique and make sure you are getting low to the water when on the righting line. My daughter and I started sailing this year. Our combined weight is about 310 lbs. We have capsized a few times, and the boat has come right up without turning it into the wind in 15 mph wind. If your combined weight is much less that that, or the wind speed much higher, you might need to turn the boat into the wnd to help you out. I'm sure there will be a point with higher wind speeds and bigger waves we will need to turn the boat into the wind. |
| Author: | fastcat [ Fri Sep 02, 2011 10:00 am ] |
Newsreader: First - if turtled the boat is as stable as it ever will be, so take a second to collect yourself/s. Make sure the jib & main sheets are released, the traveler is released and the hiking stick is not tangled. Then unturtle the boat standing on the leeward hull leaning out. It may come slowly, but it will. By standing on the leeward hull the wind will help get the boat on it's side with the wind pressure on the tramp. Then you can right the boat cross wind or move toward the bow and have the boat round up. |
| Author: | newsreader [ Sun Sep 04, 2011 9:14 pm ] |
Thanks for the advice. Though I rather not see that happen. fastcat wrote: Newsreader: First - if turtled the boat is as stable as it ever will be, so take a second to collect yourself/s. ..................
